I was able to run an Analysis externally, however the console logs did not display on my machine.
I also found the documentation possibly outdated, for instance in this page, the Tago Builder link does not work:
https://docs.tago.io/en/articles/174-running-analysis-as-external-using-node-js
Is there a detailed instruction on how to successfully debug analysis externally?
Thanks.
