At some point you may need to create your own parser for reasons like: you are designing your own hardware, it is not listed in our list of devices, or you just want to post-process the data coming from the connector. I will show how you can do that.
On the example above, I chose to use a snippet parse Exemple, but you can create and edit your own parser as needed.
Tip: Watch the tutorial video below:
Hey, I want to know what you think about this tip, let your comments below!
Cheers!
