Payload Parser: "TypeError: payload.find is not a function"
Hello, I am trying to parse an MQTT payload that comes in to Tago from one of my arduino devices. The payload is made of three comma separated values. Here's a pasted output from the Live Inspector for my device:
  1. { "topic": "your/mqtt/topic", "payload": "455, 68.30, 123.40", "qos": 0, "isHex": false, "bucket": "xxxxxxxxxxxxxxxxxxxxxxxxxx", "messageId": 0 }
(i have removed my actual bucket ID from the above code) .
In my Payload Parser i have:
  1. const rawValues = payload.find(item => item.variable === "payload");
    if (rawValues)
      const valuesString = rawValues.value;
      const splitValues = valuesString.value.split(',');
      const iBatt = splitValues[0];
      const battSoc = splitValues[1];
      const packVolts = splitValues[2];
    payload.push({"variable": "BattCurrent", "value": iBatt, "unit": "A"});
    payload.push({"variable": "SoC", "value": battSoc, "unit": "%"});
    payload.push({"variable": "packVolts", "value": packVolts, "unit": "V"});
No variables appear in my Buckets -> (Device) -> Variables tab.
If i paste an output from the live inspector into the Emulator, i get the error "Function Parse Error: TypeError: payload.find is not a function"
I would be grateful if someone could point out where i'm going wrong. If needed i could change the MQTT payload on the arduino if it makes things easier
Thanks
Tom
