Payload parser multiple devices to one LoraWAN gateway
Hello,
I am decoding the payload raw from 3 dragino devices that are conected to one gateway (ITG-200).
I need to check if statement is true to concat the right var data[] to the payload.
How can I do it?
I have the problem with this function
function dataConcat(k) {
  if(k === 'A84041C6918349CE' || 'A84041AC918399DE' ) {
      return [
      { variable: k + 'hex', value: console.log('primo') },
      { variable: k + 'hex', value: console.log(device) },
      { variable: k + '_BAT', value: batV /1000, unit: 'V' },
      { variable: k + '_temperature',  value: temp_DS18B20, unit: '°C' },
      { variable: k + '_distance_cm',  value: lidarDistance[0], unit: 'cm' },
      { variable: k + '_Distance_signal_strength',  value: lidarDistance[1] },
      { variable: k + '_lidar_temperature',  value: lidarDistance[2], unit: '°C' },
      { variable: k + '_flags',  value: messageAndFlags[0] },
      { variable: k + '_message',  value: messageAndFlags[1] }
  } else if(k === 'A840418A2182DC01' ) {
    return [
        { variable: k + 'hex', value: console.log('secondo') },
        { variable: k + '_water_SOIL',  value: nonContactLiquid[0], unit: '%' },
        { variable: k + '_temperature_SOIL',  value: nonContactLiquid[1], unit: '°C' },
        { variable: k + '_conduct_SOIL',  value: nonContactLiquid[2], unit: 'us/cm' },
  } else if(k === 'A84041FBB18399EC') {
    return [
      { variable: k + 'hex', value: console.log('terzo') },
      { variable: k + '_N',  value: soilMeasurement[0] },
      { variable: k + '_P',  value: soilMeasurement[1] },
      { variable: k + '_K',  value: soilMeasurement[2] },
  } else {
    //do nothing
It only return the first if statement. Like this:
        "variable": "A84041FBB18399EC_device_eui",
        "value": "A84041FBB18399EC",
        "serie": "1656415416908",
        "time": "2022-06-28T11:23:23.000Z"
        "variable": "A84041FBB18399EC_last_message_received",
        "value": "28/06/2022 08:23:36",
        "variable": "A84041FBB18399EC_uplink",
        "value": 286,
        "time": "2022-06-28T11:23:23.000Z",
        "unit": "count"
        "variable": "A84041FBB18399EC_activation_mode",
        "value": "OTAA",
        "variable": "A84041FBB18399EC_bandwidth",
        "value": "125",
        "unit": "kHz"
        "variable": "A84041FBB18399EC_spreading_factor",
        "value": "10",
        "variable": "A84041FBB18399EC_datarate",
        "value": 2,
        "variable": "A84041FBB18399EC_rssi",
        "value": -63,
        "unit": "dBm"
        "variable": "A84041FBB18399EC_quality",
        "value": "Forte",
        "variable": "A84041FBB18399EC_snr",
        "value": 9.2,
        "unit": "dB"
        "variable": "A84041FBB18399EC_payload_raw",
        "value": "0d170000027600a8000001",
        "variable": "A84041FBB18399EC_gateway",
        "value": "0000F8033201CF1D",
        "variable": "A84041FBB18399EChex",
        "variable": "A84041FBB18399EC_BAT",
        "value": 3.351,
        "unit": "V",
        "variable": "A84041FBB18399EC_temperature",
        "value": "0.00",
        "unit": "°C",
        "variable": "A84041FBB18399EC_distance_cm",
        "value": 63,
        "unit": "cm",
        "variable": "A84041FBB18399EC_Distance_signal_strength",
        "value": -88,
        "variable": "A84041FBB18399EC_lidar_temperature",
        "value": 0,
        "unit": "°C",
        "variable": "A84041FBB18399EC_flags",
        "value": 0,
        "variable": "A84041FBB18399EC_message",
        "value": 1,
I attach my code and the live inspector.
Thanks
Michelangelo
