Non-location variables in the Infobox of the Map widget (new Normal Dashboard)
@dev el
Hi,
I’ve multiple sensors which I want to show on the map widget. Besides the ‘location’ variable each sensor has further variables like ‘pressure’, ‘battery status’ and so on. Some of these variable should be shown in the Infobox.
Unfortunately I do not find a way to configure the map widget properly. If I setup additional variables in the “Data from” section, these variables are interpreted as locations too. I have searched in the forum, but only found solutions for the old Dashboard GUI, where you could configure how each variable should appear (see here).
Do I miss something or has the new Dashboard GUI some limitations?
Best regards,
devel
