Multiple hosts running the same external analyses
Hi,
I was wondering what happens if multiple host run the same analysis externally so I did a quick test with two hosts... Both hosts connect successfully to Tago.io and both hosts receive and execute the analysis.
Is that expected? And if so, does that mean that device data is potentially updated/generated multiple times for 'the same' analysis run?
Cheers,
Erwin
