Multi variable Custom Widget
Looking for a developer to create a custom widget to show temperature plus the device name temperature is associated with
we have on data stream with data from multiple devices providing temp, humidity , etc
what I require is a temp widget that shows temp and possible other sensor data in one widget along with device name which is unique
Thanks
