Minimum, maximum, and average. - how to modify
Hello,
Can anyone advise how to modiify analisys Minimum, maximum, and average.
I would like to use it for more then 30 devices, so my plan is to use in Environment Variables account token instead device token and in code have possibility to add  devices.
Below code  i would like to change
 * Analysis Example
 * Minimum, maximum, and average
 * Get the minimum, maximum, and the average value of the variable temperature from your device,
 * and save these values in new variables
 * Instructions
 * To run this analysis you need to add a device token to the environment variables,
 * To do that, go to your device, then token and copy your token.
 * Go the the analysis, then environment variables,
 * type device_token on key, and paste your token on value
const { Analysis, Device, Utils } = require("@tago-io/sdk");
// The function myAnalysis will run when you execute your analysis
async function myAnalysis(context) {
  // reads the values from the environment and saves it in the variable env_vars
  if (!env_vars.device_token) {
    return context.log("Device token not found on environment parameters");
  const device = new Device({ token: env_vars.device_token });
  // This is a filter to get the minimum value of the variable temperature in the last day
  const minFilter = {
    variable: "temperature",
    query: "min",
    start_date: "1 day",
  // Now we use the filter for the device to get the data
  // check if the variable min has any value
  // if so, we crete a new object to send to TagoIO
  const [min] = await device.getData(minFilter);
  if (min) {
    const minValue = {
      variable: "temperature_minimum",
      value: min.value,
      unit: "F",
    // Now we send the new object with the minimum value
    await device
      .sendData(minValue)
      .then(context.log("Temperature Minimum Updated"));
  } else {
    context.log("Minimum value not found");
  // This is a filter to get the maximum value of the variable temperature in the last day
  const maxFilter = {
    query: "max",
  const [max] = await device.getData(maxFilter);
  if (max) {
    const maxValue = {
      variable: "temperature_maximum",
      value: max.value,
      unit: "F",
    await device
      .sendData(maxValue)
      .then(context.log("Temperature Maximum Updated"));
  } else {
    context.log("Maximum value not found");
  // This is a filter to get the last 1000 values of the variable temperature in the last day
  const avgFilter = {
    qty: 1000,
  const dataAvgArray = await device.getData(avgFilter);
  if (dataAvgArray.length) {
    let temperatureSum = dataAvgArray.reduce((previousValue, currentValue) => {
      return previousValue + Number(currentValue.value);
    }, 0);
    temperatureSum = temperatureSum / dataAvgArray.length;
    const avgValue = {
      variable: "temperature_average",
      value: temperatureSum,
      unit: "F",
    await device
      .sendData(avgValue)
      .then(context.log("Temperature Average Updated"));
  } else {
    context.log("No result found for the avg calculation");
module.exports = new Analysis(myAnalysis);
// To run analysis on your machine (external)
// module.exports = new Analysis(myAnalysis, { token: "YOUR-TOKEN" });
