LT-22222 Dragino relay dashboard push button config
Hi, I am trying to figure out how to turn this relay on and off with the push button widget, but having some issues. I configured it with the helpful tech staff at Dragino, and it is running like a song through TTN. I set it to MOD1 and the payload code at 03 00 00 .... This is the setting if you want to use the relay be used to control the RO1 and RO2. I am using this Dragino LT relay to trigger 2 solid state relays, that turn appliances on and off. I want to figure out how to do it with the push button first, and then I will tackle triggering it through analysis and all that good stuff. Any help or clues of how to go about this would be great and much appreciated, because frankly I am kind of lost. There are a couple screenshots below that might help.
