LR1110 Connector Service Discontinuation Notice
We're announcing that the LR1110 connector will be discontinued effective July 31st. This decision follows Semtech's discontinuation of their LoRa Cloud geolocation services, which the connector depends on for functionality.
If you're currently using LR1110 devices, you'll need to migrate to an alternative solution. We recommend transitioning to AWS IoT Device Location, which provides similar geolocation capabilities.
Given the timeline, you should start the migration process soon. You can find detailed setup instructions for AWS IoT Device Location integration at: https://help.tago.io/portal/en/community/topic/how-to-integrate-with-aws-iot-core-device-location
The AWS IoT Device Location service should provide equivalent positioning accuracy and coverage for your devices. The integration process is straightforward and the service offers reliable geolocation functionality.
If you encounter any issues during the migration process or have questions about transitioning from the LR1110 connector, please post them in this thread. We'll monitor this discussion and provide assistance where needed.
