LoRaWAN (Helium) Connector Parser
Has anyone else noticed a change to the LoRaWAN connector parser (Helium in my case) where the variables are now split out in to "x_value", "x_name", "x_type", "x_unit", "x_channel" and so on?
Previously it was "x" which then had the name/value pairs nested within. The dashboard widgets could then show the data in one view as a single variable. So a voltage variable would have the value, "V" for volts embedded in the data.
I don't want to mess around with my input function to correct this as it was working fine up until midday yesterday!!
Thanks,
Mark
