Line Chart Widget with multiple metadata vars
Hi guys!
I am trying to use a line chart widget with multiple lines. The data come from only one var with multiple metadata properties, but, I dont know if is because is the same var, the line chart remove all the var, leaving just one.
Let me put some images:
two vars with the respective metadata formula to get the correct information.
After save, just one var.
Is not possible to do what I am trying?
