Issues with running analysis from another analysis (Python API)
Hello.
I have an issue where running calling one analysis from another. I went back to calling my_account.analysis.list(), and found even that had errors. I know that my_account is functioning correctly because that is how I pull controller the controller ID, which is working.
Both are Python Analyses. Here is the snippet I have been running i
elif leaf_moisture > 25:
#update_variable(controller, "ro2_command", "OFF")
scope = [{'variable': 'ro2_command', 'value': 'OFF', 'device': controller_dev_ID}]
#my_account.analysis.run('OHC_ANALYSIS_ID', scope)
analysis_info = my_account.analysis.list() context.log(analysis_info)
This is the Error I get.
- [2022-08-08 20:48:53]
{'status': False, 'result': {'request_error': 'Unexpected token p in
JSON at position 0', 'request_body':
'page=1&fields=id&fields=name&amount=20&orderBy=name%2Casc',
'server_response': 'Malformed request syntax'}}
