Hi everyone,
I have found a strange issue when migrating my Dragino GPS Tracker LGT-92 from TTNv2 to TTIv3.
I used the instructions found here How to integrate TagoIO with TTI / TTN v3
After replicating the application in TTNv3 I longer get the “location” field in TagoIO.
I am getting all of the other fields including latitude and longitude but no “location”.
I can’t figure out if the location field is generated by TagoIO (documentation suggests it should be) https://docs.tago.io/en/articles/135-displaying-locations-on-a-map-with-ttn-lorawan
Strangely I am also no longer getting altitude out of TagoIO. Yet I am using the same decode script as I was using on TTN v2. (Which did not explicitly export altitude)
Using firmware 1.5 (not changed)
Anyone have an idea?
Does the LGT-92 under TagoIO perform its own packet data extraction?
ps I know TTNv3 is super super new so it might be something on the TTN/TTI side.
