Hey everyone:
I was trying to upload a file from analysis without success.
My code:
const account = new Account({ token: env_vars.account_token });
const testBuffer = Buffer.from("hello world", "utf-8");
const filename = "test.csv";
const response = await account.files.uploadFile(testBuffer, filename, {
contentType: "text/csv",
// also tested with promises .then() & .catch()
Error throws
(node:98094) UnhandledPromiseRejectionWarning: Error: Could not upload part number 1: undefined
at Files._addToQueue (/my_project/node_modules/@tago-io/sdk/out/modules/Account/Files.js:217:27)
(Use `node --trace-warnings ...` to show where the warning was created)
(node:98094) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 6)
(node:98094) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
error uploading Error: Could not upload part number 1: undefined
Anyhow, i’ve just changed the upload function and it worked, but i’m really don’t like much Base64.
const response = await account.files.uploadBase64([
filename: `/my_csv_files/${filename}`,
file: testBuffer.toString("base64"),
Thanks!
