Is there a problem with the zoom settings for the map widget?
Hello,
I encountered a problem that I will try to describe below.
If I put more than one map widget in the dashboard, the maps always appear zoomed to only 6% after loading and even though I have the default zoom set to 75%.
I have to move the map a bit and then click on the square to set the basic zoom to 75%.
The error manifests itself in the application on Android and also in the browser on PC.
If I insert only one map widget into the dashboard, it works correctly.
I am attaching the screen of the widget and the screen of its settings.
Petr
    • Topic Participants
    • Petr
