Hi
I have picked up an issue with the input form widget.
The problem lies with the field type calendar.
If you select a date and submit it
The date is saved to the variable incorrectly. It seems out by one day and is saved as a START date as if you were inputting a range of dates, i want a standalone date and did not select “show end date”.
This is the result from the variable date.
It should be outputted as was originally inputted.
05/01/2021
Kind Regards
Flaxies
