Input control Widget - Default value option
@Brugnetti brugnetti
Hello,
In the Dashboard, I create an “Input control”. This “Input control” has 3x fields, and each one are defined as “Default value = Last”
When the user change the value of the fields, the variable assigned to these fields are correctly assigned to the bucket variable. The problem is that when the user close the Dashboard and reopen it, 2x fields indicate the default values and, only one indicate the previous value.
Is possible to visualize the previous value with all 3x fields ?
Thanks
