Icon Widget config keeps loosing formula setting
@Vincent Raaijmakers
I noticed the following undesired behavior.
When creating an Icon Widget and using the Variable setting in Formula, the Variable setting (input provided) gets lost every time when you re-open the widget. And as a result, you need to reconfigure the variable again, each time when opening the widget. So, selecting the device, selecting the variable again. Pretty annoying. Is that a known defect?
Just FYI.
Vincent
