HTTP to TagoIO JSON transition
Hello,
Could anyone recommend the correct snippet for HTTP to TagoIO JSON transition based on the following payload example?
POST] HTTP Request:
"From: 132.145.241.176 [Unknown] - Content-Type: application/json - Token Ending: 68dcc"
22:16:48:
Raw payload:
{ "rcvTime": 1726258607, "srcImsi": "901288910226417", "ID": "24090254", "ID_unit": "24090254 ", "Battery voltage": 3570, "Battery voltage_unit": "3570 mV", "RSSI": -66, "RSSI_unit": "-66 dB", "T": 22, "T_unit": "22 C", "T2": 0, "T2_unit": "0 C" }
22:16:48:
Connection refused, invalid payload:
"[object Object]"
Best regards,
