HTTP Arduino
HTTP Arduino
Good morning, I'm writing via http on arduino, but only one variable. Do you have any examples of multiples? I need to write 5 simultaneous. Below is the format I'm using for a variable:
//Inicia um client TCP para o envio dos dados
  if (client.connect(server1, 80)) {
    String postStr = "";
    String postData = "variable=temp&value="+String(motor_tensao)+"\n" ;
    Serial.print("CONECTADO NA TAGO\n");
    postStr = "POST /data HTTP/1.1\n";
    postStr += "Host: api.tago.io\n";
    postStr += "Device-Token: " + apiKey + "\n";
    postStr += "_ssl: false\n";
    postStr += "Content-Type: application/x-www-form-urlencoded\n";
    postStr += "Content-Length: " + String(postData.length()) + "\n";
    postStr += "\n";
    postStr += postData;
    client.print(postStr);
