[Webinar] How to improve data management
Hi all!
We recently had a very informative webinar about how to get the most out of your data storage. If you want to learn all the secrets and best practices that we showed in this webinar, you watch it here:
We showed how to utilize metadata to store additional data and use Formula to access the metadata information in widgets. By using metadata, your additional information won't count in your data usage.
Next, we explored effective data retention strategies. Attendees learned how to implement smart data retention scripts, reducing storage costs while retaining the data needed for analysis and reporting.
Finally, we showed attendees how to filter the data sent by devices using the payload parser. If you will use only some of the data your device is sending, it's a good idea to filter it so that you save your precious data storage within TagoIO.
Discover exciting webinars and events!
Find other webinars to enrich your knowledge by checking our Youtube channel or subscribing to our future webinars.
