How to edit metadata.label in blueprint dynamic table?
@Erwin Hogeweg
Hi,
I have a dynamic table which shows the variables of blueprint devices. One of the variables is called device_name, and it has a value property and a metadata.label property.
In the table the column shows the metadata label as expected. However, when I edit the value in that column the field switches from device_name.metadata.label to the device_name.value property. See screenshots.
I don’t see an option to enforce editing the metadata.label. Am I missing something?
Thanks,
Erwin
