Hello,
I want to know how I can display 2 variables readings in one message.
For example, if I want to display the temperature data from my device I would just do something like:
Variable: Temperature. Value: 25. Unit: C.
The $VARIABLE$ is $VALUE$ $UNIT$ .
The temperature is 25C.
What if I want to send another variable input data in the same message. For example the humidity readings too? How do I do it?
Variable: Humidity. Value: 35.
