Hi TagoIO community,
I am new to IoT and trying to create a plant watering system using arduino, TTN and TagoIO.
I am trying to use two step button widgets to set humidity and temperature values and downlink this pair of values to the device (see screenshot).
I am unsure how to go about this. I am aware of the available analysis template and the input form template (which works fine), but need some help with configuring two step buttons (perhaps send as JSON data).
Thanks in advance
