How to connect uRAD sensor to TagoIO device using https
uRAD provides access to sensor data via an API. Using simple https calls with passed parameters to authenticate the request. (api docs:
uRADMonitor_server_specs_02_comp.pdf )
I am able to use Postman to easily get the data I want but I am having trobule setting up a device in TagoIO to capture/visualize the data.
I selected the custom HTTPS device, I was also able to add in my required 2 parameter key/values but I don't see a way to enter the GET uri.
