How to bundle a plugin for local use?
Hi,
I am pretty sure I have read/seen this somehwere but I can't find it anymore. I have a plugin directory in my development machine and I want to load this plugin in tagocore docker container. When I select the 'install local plugin' button and then select the folder with the plugin, nothing appears to happen, and I verified that the plugin is not installed in the container. I believe (...) that I need to create a .tcore file, but I can't find the instructions anymore.
Any advice is greatly appreciated.
Cheers,
Erwin
