How to access Device query using listDevice ?
Hi,
I am trying to use filter in listDevice to access device query but the function is returning query object of other device. Expected Device ID and returned device ID does not match. I have used filter in Java script works fine but in python script i am facing this issue. Would be great if you let me know is it the correct way to use filter?
  1.      print("Expected Device-id: ",device_id)
            aux_dev_item = account.devices.listDevice( {
                    "filter": {
                    "tags": [
                        { "key": "device_type", "value": "aux" },
                        { "key": "device_id", "value": device_id }
                    "amount": 20
Thank you
