Hello everyone,
On Tago, we understand that there's a need to be flexible while working with Open-Source solutions, that being said, TagoCore, our free, fast, and open-source IoT platform for edge computing, works very well while integrating multiple third-party solutions in the application- even while having the full compatibility and integration with our TagoIO already.
Grafana is one of the multiple third-parties applications compatible with TagoCore. While TagoIO allows you to easily integrate TagoCore, Grafana can be used to visualize data Offline, as some users were more familiar with Grafana because they've used it before, making a tutorial about How to Visualize Data on Grafana from TagoCore, which makes the integration much easier and increases the possibilities and utilities from TagoCore as well.
As shown in the image attached below, Grafana has a vast amount of customizable widgets which allow you to create multiple views and charts about the devices and information you need, working together with TagoCore, both applications turn into a powerful IoT solution.
