Getting Started
Getting Started
@Brien Hamilton
It is awesome that Tago.io has the connection I need, (Seeed SenseCap Soil Moisture and Temperature Sensor). Is there some guidance on where to get, (or how to generate), the decoder script that needs to be used in the Helium console?
I am not a programmer, so I was hoping to find a easy script writing interface that would pretty much write the necessary code from simpler choices of functionality.
In particular, the script I am using, was received from sensecap, and appears to be transmitting data every hour. Once an hour is great for a working system but horrible for troubleshooting.
I could use a little help from someone that has integrated the Seeed SenseCap Soil Moisture and Temperature Sensor into the Tago.io platform.
Thanks
Brien
