Hi Everyone
I think my issue is more of a script writing problem rather than a logic problem and i hope someone can help me to move forward.
I have an analysis to check if a location is within a geofence then initiate a notification.
The problem is that the script runs well till it gets to the call checkZones, here it hangs.
Here’s the call:
> // Get the geofence meta data and put it into a list
> const zones = geofence.map((geofence) => geofence.metadata);
> const geofence_list = zones[0];
> context.log("geofence_list = ",zones[0]);
> // Split location into lat long for point
> const latlong = location[0].value.split(",");
> //context.log("lat =", latlong[0]);
> //context.log("long =", latlong[1]);
> const point = [latlong[1], latlong[0]];
> context.log("point =", point);
> //Call the function insideZones to see if the device is in a geofence or not
> const insideZones = await checkZones(point, geofence_list);
And here’s the function:
> // This function checks if our device is inside any geofence
> async function checkZones(point, geofence_list) {
> context.log('Running checkzones');
> const insideZones = [];
> // The line below gets all Polygon geofences that we may have.
> const polygons = geofence_list.filter((x) => x.geolocation.type === "Polygon");
> if (polygons.length) {
> // Here we check if our device is inside any Polygon geofence using our function above.
> for (const polygon of polygons) {
> if (insidePolygon(point, polygon.geolocation.coordinates[0])){
> insideZones.push(polygon.event);
> // The line below gets all Point (circle) geofences that we may have.
> const circles = geofence_list.filter((x) => x.geolocation.type === "Point");
> if (circles.length) {
> // Here we check if our device is inside any Point geofence using a third party library called geolib.
> for (const circle of circles) {
> if (geolib.isPointWithinRadius
> ({latitude:point[1],longitude: point[0] },
> {latitude: circle.geolocation.coordinates[0], longitude: circle.geolocation.coordinates[1] },
> circle.geolocation.radius)) {
> insideZones.push(circle.event);
> return insideZones;
I would appreciate any help.
Thanks
Steven
