Fixing Map and Pin possible (Desktop and Tago Run)
Hello,
I have two questions. Our GPS tracker sends the data correctly. The pin disappears from the map after a while, even though I have activated Range & Format - Show only last location of variable in the settings. Range of Date is forever for past and future. What else is missing?
The second question: I only want to see Iceland when I start the world map, for example. And not just on the PC but also in the Tago Run app. Is that possible?? Under Options I have set "Open the map with a fixed zoom to 73%. That doesn't work.
Can anyone help? Thanks
I have another problem. I see the pin on the map. If I close the app or the browser and open it again, the pin disappears and only appears again when the object is moved again.
