Field limit on getData
@Gary Howell
Hello,
Is there a limit on the number of fields you can include in a data query.
I tried 30+ fields and the resultant getData data was empty.
If I shortened the field list to 20 or less it worked.
  var myFilter = {
    variable: <is there a field list limit here??>,
    qty: 1
  var data = await device.getData(myFilter);
