Hi, On running the sample geofence example, I encounter these errors. What am I doing wrong? Thanks.
[2021-10-15 13:45:22] Analysis finished.
[2021-10-15 13:45:22] (node:273) UnhandledPromiseRejectionWarning: Device can’t be found
(Use
node --trace-warnings ...
to show where the warning was created)
[2021-10-15 13:45:22] (node:273) UnhandledPromiseRejectionWarning: Unhandled promise rejection.
This error originated either by throwing inside of an async function without a catch block, or
by rejecting a promise which was not handled with .catch(). To terminate the node process on
unhandled promise rejection, use the CLI flag --unhandled-rejections=strict
(see
Command-line options | Node.js v17.1.0 Documentation). (rejection id: 2)
(node:273)
[DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future,
promise rejections that are not handled will terminate the Node.js process with a non-zero exit
code.
[2021-10-15 13:45:22] Running
[2021-10-15 13:45:22] > TagoIO-SDK: No region or env defined, using fallback as usa-1.
[2021-10-15 13:45:20] Starting Analysis…
[2021-10-15 13:45:20] Analysis Called.
