Error in ChirpStack integration with Tago Core
Hi,
I've been tinkering around with Tago Core (running v. 0.3.1 at the moment). However, I can't get it working with our existing ChirpStack framework.
For testing purposes I made a new VM with a blank TagoCore and ChirpStack installation (both in the same machine), then set-up the ports and whatnot form the TagoCore's end, and the HTTP integration from the ChirpStack's side. After that, I create a new device in both platforms and link them with their EUI. Also, I put the parser that I normally use on our normal Tago IO application for this type of sensor.
So far, it should work, right?
But whenever the sensor sends data, I got this error in the log from TagoCore:
  1. [10:02:54.380]: Error inserting data
  2. [10:02:54.380]: ZodError: [ { "code": "invalid_type", "expected": "string", "received": "undefined", "path": [ 0, "variable" ], "message": "Required" } ] at new ZodError (/snapshot/tcore/packages/tcore-api/node_modules/zod/lib/ZodError.js:80:28) at handleResult (/snapshot/tcore/packages/tcore-api/node_modules/zod/lib/types.js:115:21) at ZodArray.<anonymous> (/snapshot/tcore/packages/tcore-api/node_modules/zod/lib/types.js:231:47) at step (/snapshot/tcore/packages/tcore-api/node_modules/zod/lib/types.js:59:23) at Object.next (/snapshot/tcore/packages/tcore-api/node_modules/zod/lib/types.js:40:53) at fulfilled (/snapshot/tcore/packages/tcore-api/node_modules/zod/lib/types.js:31:58)
I'm not entirely sure of how to proceed from here or if I messed up something. I think at least I should get the raw payload from ChirpStack as TagoIO does, do I?
I understand that Core is still in development, so if it's something it will be addressed later it's ok. But if someone has managed to integrate both platforms correctly,  I will appreciate any insight.
