Environment variables with dash 6
@julien terrier
Hello,
I had an issue in my analysis script if in Environment variables tab I set a variable with dash 6 (-).
For example:
A1-Token doesn’t work while A1_Token works.
Certainly you can reproduce this issue rapidly.
Clearly it’s not a pb I changed the name of the envirnoment variables but I debugged during 3 hours to find that
May be this issue is already reported?
Don’t hesitate if it’s not clear.
Thank you
