const { Analysis, Account, Utils, Device } = require("@tago-io/sdk");
async function startAnalysis(context, scope) {
if (!scope[0]) {
return context.log("The analysis must be triggered by a widget.");
context.log("Creating your device");
const env = Utils.envToJson(context.environment);
if (!env.account_token) return context.log('Missing "account_token" environment variable');
else if (env.account_token.length !== 36) return context.log('Invalid "account_token" in the environment variable');
const account = new Account({ token: env.account_token });
const dashboard_dev_token = await Utils.getTokenByName(account, scope[0].device);
const dashboard_device = new Device({ token: dashboard_dev_token });
const network_id = scope.find((x) => x.variable === "device_network");
const connector_id = scope.find((x) => x.variable === "device_connector");
const device_name = scope.find((x) => x.variable === "id_tienda");
const nombre = scope.find((x) => x.variable === "nombre");
const device_eui = scope.find((x) => x.variable === "id_tienda");
const region = scope.find((x) => x.variable === "region");
const zona = scope.find((x) => x.variable === "zona");
const tamano = scope.find((x) => x.variable === "tamano");
const status = scope.find((x) => x.variable === "status_operativo");
const direccion = scope.find((x) => x.variable === "direccion");
const email = scope.find((x) => x.variable === "email");
const tienda_user = scope.find((x) => x.variable === "tienda_user");
const solar_activa = scope.find((x) => x.variable === "solar_activa");
const check_eolica = scope.find((x) => x.variable === "check_eolica");
const entidad = scope.find((x) => x.variable === "entidad");
const cp = scope.find((x) => x.variable === "cp");
const gerente = scope.find((x) => x.variable === "gerente");
const id_cont = scope.find((x) => x.variable === "id_cont");
const carga = scope.find((x) => x.variable === "carga");
const demanda = scope.find((x) => x.variable === "demanda");
const no_medidor = scope.find((x) => x.variable === "no_medidor");
const tarifa = scope.find((x) => x.variable === "tarifa");
const multiplicador = scope.find((x) => x.variable === "multiplicador");
const facturacion = scope.find((x) => x.variable === "facturacion");
if (!connector_id || !connector_id.value) {
return context.log('Missing "device_connector" in the data scope.');
} else if (!network_id || !network_id.value) {
return context.log('Missing "device_network" in the data scope.');
} else if (!device_eui || !device_eui.value) {
return context.log('Missing "device_eui" in the data scope.');
const result = await account.devices
.create({
serie_number: device_eui.value,
tags: [
{ key: "CUENTA", value: "RETAIL" },
{ key: "TIENDA", value: nombre.value },
{ key: "device_eui", value: device_eui.value },
{ key: "REGION", value: region.value },
{ key: "ZONA", value: zona.value },
{ key: "TAMAÑO", value: tamano.value },
{ key: "ESTADO", value: status.value },
{ key: "DIRECCION", value: direccion.value },
{ key: "SOLAR", value: solar_activa ? solar_activa.value.toString() : '' },
{ key: "EOLICA", value: check_eolica ? check_eolica.value.toString() : '' },
connector: connector_id.value,
network: network_id.value,
active: true,
type: "mutable",
chunk_period: "month",
chunk_retention: 13,
.catch((error) => {
dashboard_device.sendData({ variable: "validation", value: `Error when creating the device ${error}`, metadata: { color: "red" } });
throw error;
