Dynamic table filtering questions
@Andrés
Hello!
I have a few questions related to filtering dynamic tables which I haven’t been able to find in the forum:
- Is there any way to filter a table permanently depending on the value of a variable? Let’s say I have a variable called User, can I only show in the table the series of data which have the User variable value “Manuel” for example? I guess this can be done through an analysis but I guess there may be an easier way to go.
- When filtering the table with the search option and you export the table to .xlsx or .csv all the table is downloaded, instead of just the fields which are shown due to the search filter. Is there any way to download just the fields which are shown after searching?
Thank you for your time! Regards,
Andrés
