Detecting Applied Filters in Map Widget
Hi.
I am using filters within the Map widget. Is there a way to detect which filter has been applied in the observed widget by using TagoIO analysis and SDK methods?
For example, the goal is for the user to trigger an analysis by clicking the header button Generate Report for the selected objects, which will create a report for the marked objects on the map that are included by the selected filter.
I am grateful in advance for your suggestions and answers.
Best regards,
Nemanja
