Cylinder Widget - Range from variables
Hello,
I am trying to utilize the Cylinder Widget. The user will need to specify the max height of their tank. My original plan was to utilize the Input Control module, but I am not sure if that is correct.
What is the proper way to ask the user to input the tank height, and utilize this info in the range value for the Cylinder Widget?
