Hello,
I have an IoT sensor. I created a software to connect this sensor with TTN or Swisscom networks depending of signal strength. For this sensor, on Tago.IO I created 2 different devices (because Networks and connectors are different) and, those devices are linked on the same Bucket. The problem is that in the Dashboard the Widget can link only one defined device.
Does is possible to link a Widget to multiple devices ?
Thanks
