Clear SetTimeout timeout in Tagoio ?
From the following code, how can I manage to delete the setTimeout so that Analysis does not consume me since I have a waiting time of 1 minute if it is "Door Open" . If a "Door Close" data arrives, the Analysis should cut the SetTimeOut of "Door Open" but it doesn't keep running.
const { Analysis, Device, Utils } = require("@tago-io/sdk");
async function hdaEncantada(context) {
  try {
    const vivid_master = new Device({ token: env_vars.vivid_master });
    const vivid_data = new Device({ token: env_vars.vivid_data });
    const result_master = { variable: "hall_effect_state", qty: 7 };
    const array_master = await vivid_master.getData(result_master);
    const state_master = array_master.map((data) => data.value);
    console.log("STATE MASTER -->", state_master);
    const result_data = { variable: "master_simulacion", qty: 1 };
    const array_data = await vivid_data.getData(result_data);
    const state_data = array_data.map((data) => data.value);
    console.log("master -->", state_data);
    const result_ahorro = { variable: "ahorro_simulacion", qty: 1 };
    const array_ahorro = await vivid_data.getData(result_ahorro);
    const state_ahorro = array_ahorro.map((data) => data.value);
    console.log("ahorro -->", state_ahorro);
    const strega_master = new Device({ token: env_vars.strega_master });
    const now = new Date();
    const hour = now.getHours();
    const minute = now.getMinutes();
    const second = now.getSeconds();
    if (state_data[0] === 1) {
      if (state_ahorro[0] === '1') {
        const newVariable = `Open_${hour}_${minute}_${second}`;
        const newVariableClose = `Close_${hour}_${minute}_${second}`;
        // -------- DOOR OPEN --------
        if (state_master[0] === "Door Open") {
          const newData = {
            variable: "states",
            value: newVariable,
          await vivid_master.sendData(newData);
          // SET TIME OUT
          setTimeout(async () => {
            const latestData = await vivid_master.getData({ variable: "states", qty: 1 }); // Obtener el último dato creado
            const latestValue = latestData[0]?.value || ""; // Obtener el valor de la última variable o establecer una cadena vacía si no hay datos
            if (latestValue === newVariable) {
              const newDate = {
                value: "Undefined_Open",
              vivid_master.sendData(newDate);
              // ---------------------------  APAGAR AIRE MASTER -------------------------------------
              const newMaster = {
                variable: "switch",
                value: 0
              await strega_master.sendData(newMaster);
              console.log("MASTER --> APAGAR");
              console.log(`La última variable creada coincide con ${newVariable}`);
              // ------------------------ FIN APAGADO --------------------------
            } else {
              console.log(`La última variable creada no coincide con ${newVariable}`);
          }, 60 * 1000);
        // ------------------------------ DOOR CLOSE --------------------------
        else if (state_master[0] === "Door Close") {
          // -------------- NEW VARIABLE -------------------------
          const newData = {
            variable: "states",
            value: newVariableClose,
          //---------- SET TIME OUT -----------
            if (latestValue === newVariableClose) {
              const newDate = {
                value: "Undefined_Close",
              // -------------- ENCENDER AIRE MASTER -----------------------------
              const newMaster = {
                variable: "switch",
                value: 1
              console.log("MASTER --> ENCENDER");
              console.log(`La última variable creada coincide con ${newVariableClose}`);
              // ------------------------------ FIN ENCENDIDO --------------------
            } else {
              console.log(`La última variable creada no coincide con ${newVariableClose}`);
          }, 15 * 1000);
      } else {
          newData = {
        } else if (state_master[0] === "Door Open") {
          newData = {
          return;
    } else if (state_data[0] === 0) {
        const newData = {
        const newData = {
      return;
  } catch (error) {
    console.log(error);
module.exports = new Analysis(hdaEncantada);
