Hi,
I’m not sure if I understood correctly the instruction to change the color of the lines within a chart. If I put in the field ‘variable’ a JSON containing the metadata, I receive an error saying: “Variable field should NOT contain special characters such as *?!<>.-=$ or space”
Where exactly can I change the color of a line?
Thank you!
