Chart Style Improvement Ideas
Hello,
I'm loving the improved chart functionality and just have a few additional feature requests.
1) We're using a multiple axis chart and would prefer to use a fixed axis. However, it appears that the scale of the fixed axis applies to both Y axis values. Is it possible to have Y1 scale from 0-200 and Y2 scale from 0-60?
2) You can set a line color per variable, but it doesn't seem like you can set a line style (dotted/dashed etc.). Would that be a possible feature in the future? It would help to improve UX for color-blind users.
3) Reference lines are fantastic, but if you have two reference lines with values close to each other then the labels overlap. Is it possible to control which side of the chart the reference line labels appear?
Thank you!
