Can not get the sensor data to show up on the dashboard.
I am trying to see the sensor data for the air temp hum device. It says it received data 11 minutes ago as seen in this screenshot. I created a widget in a dashboard and noticed that when I tried to input the Variable to use it stated "Auto Complete is Temporarily Disabled". Usually, there is a drop-down menu where you can choose the temp or humidity for the data input variable, but in this case, there is not as seen on the screenshot attached.
