I have installed several sensors which they send their data to TagoIO. Here I wan to use a python code to use the stored data and do predictions based on Machine learning. This process repeats one each day, so the python script should get all of the stored data, train a model, and use it to predict the next day.
Can I use Python, together with keras and other required libraries for data mining here?
Training of model may take several hours, is it ok in TagoIO or there is a time limitation?
Considering that one run of my Machine Learning script may take several hours, is it calculated as 1 run in cost calculation?
Apparently there is a possibility to run external programs. Can it be a solution?
I am very new to TagoIO and also to IoT so I really appreciate if the answers are simple to understand
