Hello,
I’m trying to put a blueprint dashboard together to give customers an overview of all temperature sensors (up to 10) assigned to them. Ideally, I would like to display the current temperature of each sensor as a Card or Display widget. However, each customer may have a different quantity of temperature sensors assigned to them.
Right now, I’ve got access management set up to connect each device to a customer, and 10 blueprint devices created to display the temperature on different cards. Is there any way to toggle the visibility of widgets based on a tag? That way, a customer with only 5 sensors wouldn’t see 5 blank cards. Alternatively, is there another way to handle different quantities of devices on a blueprint dashboard?
Thanks!
