Benefits TagoCore + Node-RED
Hi all,
In the webinar Node-RED was mentioned as a way to create a dashboard/HMI for TagoCore.
I see that Node-RED can also handle MQTT directly.
Can you give the benefits of using TagoCore for MQTT and using Node-RED for HMI? Why not use only Node-RED?
Nelson
