Back button in app & browser
Hello,
If you navigate to a dashboard using the device widget table it takes you to the correct dashboard, but if you hit the back button it takes you to the main run page and not the previous page you were on.
Can you guys fix this bug? When I hit the back button it should navigate right back to the widget I chose the link from.
Thanks,
