Hi.
I am doing a analysis and I have to use the function “Utils.getTokenByName” to get a device token. Worked fine some times, but stop works, after some days, worked fine some times and again stop works.
This API requests have any limitation or I missing something?
PS. No error messages appears, only not continue the script, I will put the code and prints to clarify.
const { Analysis, Account, Device, Utils } = require("@tago-io/sdk");
async function copyToDummyDevice(account = new Account(), dummy_device = new Device(), device_id = '') {
// Get the device token and instance device class.
const device_token = await Utils.getTokenByName(account, device_id);
const device = new Device({ token: device_token });
// Fetch the last location on the device, result is an array, so [last_location] automatically access index 0 of the array.
// variable we're trying to fetch is location.
const [last_location] = await device.getData({ variables: ['location'], qty: 1 });
if (!last_location) { // stop if no variable location was found in the device.
return context.log("Missing variable location for this device");
// Delete any previous value for the variable location, with serie of the device_id
await dummy_device.deleteData({ variables: 'location', series: [device_id] });
// Insert the data location, with the serie being the device_id.
dummy_device.sendData({
variable: 'location',
value: "test",
serie: device_id,
async function myAnalysis(context) {
if (!env_vars.account_token) {
return context.log("Missing account_token environment variable");
const account = new Account({ token: env_vars.account_token });
// Fetch the list of devices filtered by tag key "device_type" and value "customer"
const customer_devices = await account.devices.list({ fields: ['id', 'name', 'tags'], filter: { tags: [{ key: 'device_type', value: 'map' }] } });
for (const customer_dummy_info of customer_devices) {
// Check if there is any device with tag key "customer_id" with the value of the tag on the customer device.
const devices_to_copy = await account.devices.list({ fields: ['id', 'name', 'tags'], filter: { tags: [{ key: 'device_type', value: "pin" }] } });
if (!devices_to_copy.length) {
context.log(`No pin device found for customer ""`);
continue;
// Get the dummy device token and instance device class.
const dummy_device_token = await Utils.getTokenByName(account, customer_dummy_info.id);
const dummy_device = new Device({ token: dummy_device_token });
// Send each device to the function copyToDummyDevice.
devices_to_copy.forEach((device) => {
copyToDummyDevice(account, dummy_device, device.id);
module.exports = new Analysis(myAnalysis);
